How high should I go?
https://slantsix.org/forum/viewtopic.php?t=43064
Page 1 of 2
Author:  65CrewCabPW [ Thu Dec 30, 2010 9:40 pm ]
Post subject:  How high should I go?
Ok, I'm not putting a cam in my slant for now, but since I have to redo the head, I'm definitely going for higher compression.
I'm going to be using TBI fuel injection (not port injected, throttle body), using a Megasquirt 2, distributorless ignition ( EDIS system), no headers, super six intake, and it's a 76 engine. No air ports on the head.
So, how high should I bump this up?
I need it to run on regular gas. It will be used anywhere from 900 ft above sea level to 8000 ft above sea level.
Your input appreciated.
Author:  Fopar [ Thu Dec 30, 2010 10:56 pm ]
My guess would be no more than 9 to 1.
Richard
Author:  raPoM [ Fri Dec 31, 2010 12:18 am ]
13.5 to 1 and just run a NOS octane booster :twisted:
Author:  Charrlie_S [ Fri Dec 31, 2010 5:06 am ]
In a car, I would say about 9.0 to 9.2 to 1. In a truck that will be loaded, I would guess about 8.7 to 9.0 to 1. These would be actual measured values. You will probably have to recurve you distributor to go along with this.
Author:  66aCUDA [ Fri Dec 31, 2010 5:18 am ]
Wow that is a lot of difference in sea level. Shoot for 9 to 1 with a steel shim head gasket. Then if you need less compression use a felpro or other composite head gasket.
My02.
Frank
PS the Megasquirt II will help a whole lot.
Author:  65CrewCabPW [ Fri Dec 31, 2010 6:00 pm ]
My02.
Frank
I don't belive any of the local parts places have steel shim gaskets... Where would I find one?
Also, how does the MS help? I know I have to come up with timing curves for this thing, but is there some advantage beyond a carb?
I do not intend to have WOT enrichment...
Author:  66aCUDA [ Fri Dec 31, 2010 6:21 pm ]
Charrlie S has them in stock I am currently out but will have 30 or so in about 3 weeks.
Frank
Author:  Charrlie_S [ Sat Jan 01, 2011 6:36 am ]
I have the steel shim gaskets in stock. They are the original Mopar head gasket part number 2843182. If you want any send me a PM.
Author:  65CrewCabPW [ Sat Jan 01, 2011 12:40 pm ]
Is there anything I should know about using steel shim head gaskets? Lifespan, durability, heat, or other issues? I know that they're rarely used today, so, I'm assuming there's some reason for that.
Author:  Charrlie_S [ Sun Jan 02, 2011 6:09 am ]
They are not as forgiving as the thicker gaskets, if the head and/or deck are not flat.
Author:  Rug_Trucker [ Sun Jan 02, 2011 10:36 am ]
Do you retorque with the steel ones Charlie? Or use copper spray?
Author:  65CrewCabPW [ Sun Jan 02, 2011 11:23 am ]
I'm not pulling the motor, or tearing it down. I am going to work on the head, though, and have it milled. Since I'm going be tough on this motor ( work hard, get hot, etc) I'm wondering if that's wise. I would have no question if I had the option of decking the block to true it up. No, the gasket's not blown now, but I do know that sometimes they aren't all that flat...
What do you think?
Author:  Charrlie_S [ Sun Jan 02, 2011 2:43 pm ]
You should not have any problem. I am running them on my motors, and the decks have not ever been cut, and untill I installed the milled head on my Valiant, the head was not cut either.
I use Copper spray on the gasket, and I do retorque. The factory manual does not say anything about retorque, but I do it. I also retorque the felpro gaskets.
Author:  65CrewCabPW [ Sun Jan 02, 2011 2:46 pm ]
Much appreciated.
Author:  /6 Matt [ Sun Jan 02, 2011 3:00 pm ]
Post subject:  Re: How high should I go?
If your not using headers, you'll either want to open up the bottom and the ports of your manifold and run 2 1/4" exaust or go with dutra duals. Else your leaving alot of performance on the table with this setup...
Page 1 of 2 All times are UTC-07:00
