It is currently Mon Nov 30, 2026 2:16 am
PostPosted: Wed Jan 05, 2011 4:54 pm
Does anyone have any advice on how to change out the motor mounts without taking the engine out? What is a good jacking point to raise the engine? Does the tranny mount need to be loosened? Any advice is welcomed. Thanks
    Ken
    65 Dart Convertible Super Sixed
     Post subject: Mounts
    PostPosted: Wed Jan 05, 2011 6:54 pm
    I use a floor jack and a block of wood on the corner of the oil pan and raise the engine, one side at a time, just enough to remove the mount from the bracket and the k-frame. If you think that it may stress the tranny mount, than loosen the bolts on it.
    PostPosted: Wed Jan 05, 2011 9:48 pm
    Thanks for the info. I'll give it a try.
    Ken
    Users browsing this forum: Amazon [Bot] and 4 guests
