| Fuel/Water Separator filter https://slantsix.org/forum/viewtopic.php?t=43133 |
| Author: | Brussell [ Wed Jan 05, 2011 2:37 am ] |
| Post subject: | Fuel/Water Separator filter |
Hi, Was thinking of getting one of these filters to be on the safe side, And I wanted to mount the fuel filter away from it's current location anyways. Are they effective...? Do they give a warning light...? Are they expensive... Anyone have any ideas on what I should get for my 225...? and are they worth it...? thanks |
| Author: | olafla [ Wed Jan 05, 2011 10:32 am ] |
Hi Brussell. I just fitted my Aspen with a fuel filter/water separator combo, and it has worked just as promised. I have a heated indoor garage for my car, and driving in and out of it in the cold weather we have here, creates a lot of condensation in the fuel tank. Earlier I have used condense remover in the fuel the whole cold season, no need for that anymore. There are several filter types available, if you take a look at aggressiveTed's home page, you will see the type he uses, a spin-on canister you can get for about $35.00, if I don't remember wrong, summit has them. The filter I have is a Racor for use on boat engines (approved by the Coast Guard), it consits of a spin-on filter with a see-through clear glass bowl with a drain valve below it. Any water is clearly visible. The filter size is ten micron. I got mine from www.boatersland.com. Racor is probably the best on the market, but at a stiff price. The reason for my choice is the availability of new filter elements - we have a very long coastline full of marine equipment shops - more than for car accessories! My filter: RAC120RRAC01 Racor Fuel/water Separator $65.99 ![]() BTW, these filters are mounted on the suction side of the fuel pump, no problem about that - they have very low internal flow resistance. They can be fitted with a warning light, but as long as you can see through the filter bowl, a warning light is not really necessary. You can see the mounting instructions here. Olaf. |
