| Help on changing motor mounts on my 65 slant 6 https://slantsix.org/forum/viewtopic.php?t=43139 |
| Author: | krosan [ Wed Jan 05, 2011 4:54 pm ] |
| Post subject: | Help on changing motor mounts on my 65 slant 6 |
Does anyone have any advice on how to change out the motor mounts without taking the engine out? What is a good jacking point to raise the engine? Does the tranny mount need to be loosened? Any advice is welcomed. Thanks |
| Author: | Romeo Furio [ Wed Jan 05, 2011 6:54 pm ] |
| Post subject: | Mounts |
I use a floor jack and a block of wood on the corner of the oil pan and raise the engine, one side at a time, just enough to remove the mount from the bracket and the k-frame. If you think that it may stress the tranny mount, than loosen the bolts on it. |
| Author: | krosan [ Wed Jan 05, 2011 9:48 pm ] |
Thanks for the info. I'll give it a try. |
