It is currently Sun Nov 29, 2026 10:48 pm
 Post subject: backfire through carb
PostPosted: Thu Jan 06, 2011 5:02 pm
my engine jumped time got a new chain and gears lined up the dots put the dist on number one tdc 0 on the timeing tag on the cover new cap plugs wirers now all it wants to do is pop through the carb HEEEELLLLPPPP about to get 5 gal of gas and one match!!!!!!!!!! can any one help
PostPosted: Thu Jan 06, 2011 5:17 pm
With the dots lined up on the timing set that's usually #6 firing, not #1. Line up the timing mark on the damper and if it's pointing at #1 swap it to #6, or if it's #6, swap it to #1.
PostPosted: Sat Jan 08, 2011 7:47 pm
thanks for the help got it to run now i just need to get fuel up to the carb car has been sitting for 2 years pump or filter are bad runs on startn fluid figure it out sunday thanks again for your help
PostPosted: Sat Jan 08, 2011 7:51 pm
Be careful with starting fluid. You can wash down the cylinder walls (even more so because it has been siting) and score or even seize the pistons.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 4 guests
