It is currently Sun Nov 15, 2026 6:39 am
PostPosted: Wed Feb 09, 2011 8:51 pm
i found a VDO universal gauge on summit racing but im not certain if i should be looking for something in particular when i buy one.
im going to assume i need to match the ohm ratings for empty and full with my fuel gauge right?
my aftermarket gauge is 10 and 70
can someone help me find what i need?
PostPosted: Thu Feb 10, 2011 9:45 am
Be sure you get the low/high right - ~77 ohms is EMPTY and ~10 ohms is FULL for a Mopar sender; some gauges go the other way. The numbers are approximate and vary somewhat from sender to sender.
