| Comp 264 Cam.....I like it. https://slantsix.org/forum/viewtopic.php?t=43206 |
| Author: | Dan-o [ Tue Jan 11, 2011 10:00 pm ] |
| Post subject: | Comp 264 Cam.....I like it. |
Title says it all. Removed The Ersons 280 cam and spring set that wiped out my adjusters after a hundred miles, and installed a new 264 Comp Cam strait up. With 2.94 gears, its plenty peppy, and it gets out of its own way. Rest of the build: Shaved, Ported Heads with 1.77/1.40 valves Decked block Feather Duster Intake 3x2 Headers into a y pipe and 2.5 all the way out to a glass pack. Idles pretty smooth and is pretty peppy. Sounds cool too. |
| Author: | Fopar [ Tue Jan 11, 2011 10:49 pm ] |
I would suggest you get one of Doc's hardened gears for your oil pump. Richard |
| Author: | Dan-o [ Wed Jan 12, 2011 8:54 pm ] |
I figured I'd keep the oil thin and the RPM's shouldn't go too high with this cam. |
| Author: | Fopar [ Wed Jan 12, 2011 10:01 pm ] |
Oil is not the problem, It has to do with different hardness of cam and gear. Also how well they mesh (rough cut gear on cam) Richard |
| Author: | sandy in BC [ Thu Jan 13, 2011 3:47 pm ] |
My Comp 264 wiped out two OPDGs ......... |
