| Another 8 1/4 Rear End question..please.. https://slantsix.org/forum/viewtopic.php?t=43221 |
Page 1 of 2 |
| Author: | militos [ Wed Jan 12, 2011 1:23 pm ] |
| Post subject: | Another 8 1/4 Rear End question..please.. |
Hello every one, I just purchased a 8 1/4" Rear end, this one the guy said s that came out from a A body, it has the big bolt patern, so it be perfect for my car. The question I have today is ,,,is my existing drive shaft going to fit into that rear end, or I do have to modify it, cut or enlarge?, or any other changes I have to consider before I take my old 71/4" rear end out? Remember... my car is a Dodge Dart 1965, with a 225 slant six and a automatic trans, engine and trans are stock. thanks. |
| Author: | Joshie225 [ Wed Jan 12, 2011 2:12 pm ] |
Your driveshaft will need to be shortened as the rear U-joint of the 8 1/4 is farther forward than with the 7 1/4. According to this chart it's 1.60" farther forward. http://www.moparts.org/Tech/Archive/axle/5.html |
| Author: | militos [ Wed Jan 12, 2011 5:37 pm ] |
Thanks Señor Joshua Skinner. how about the U-joints? are they the same or I may need to modified one end of the drive shaft? thanks again. |
| Author: | Joshie225 [ Wed Jan 12, 2011 6:39 pm ] |
Oh, the u-joint is the same. |
| Author: | ESP47 [ Fri Jan 14, 2011 10:44 am ] |
I have a driveshaft here from a 73 Valiant. It went from a slant 6 and 727 tranny to an 8 1/4" rear. Not sure if it's the same length as a 904 to 8 1/4" driveshaft. Maybe someone will chime in and let us know. If it is you can come pick it up for cheap. It just doesn't have the slip yoke because I need it for my 4 speed conversion. |
| Author: | Joshie225 [ Fri Jan 14, 2011 12:23 pm ] |
727s are longer than 904s. Doesn't matter in this case though because he doesn't have a slip-yoke output transmission. |
| Author: | militos [ Fri Jan 14, 2011 1:14 pm ] |
Acording to the link that I got from Joshua Skinner I'll be modifiing my original drive shaft, I'll take it to a profesional shop to do the job do, I dont want my drive shaft falling on teh hig way. thanks every one, I just went to pick up the rear end,,it looks real clean,,no greasse at all or dirt,,I just need to take it apart , replace the seals at the ends..and so on..do some celanning and paninthing before I install it into my Baby 65 Dart. The transmission is the original one, the old previus owner lady did rebuilt the trainny before I got the car (I'm lucky). thanks again. |
| Author: | werntonb [ Wed Feb 16, 2011 10:01 pm ] |
Quote: Your driveshaft will need to be shortened as the rear U-joint of the 8 1/4 is farther forward than with the 7 1/4. According to this chart it's 1.60" farther forward.
Nice size of the rear axle. That's what I need.
| Author: | militos [ Thu Mar 17, 2011 2:10 pm ] |
mis Amigos, I have a Rear End Gera size question.. I opened the rear end to see the numbers that are stamped in the Ring gear, and this is what I have, hope some one can tellme what type of ratio I have: 2852923 245 7 21 75 2 I need to know what I have, it is a 8 1/4 rear end that I purchased few months ago. thanks. |
| Author: | Doc [ Thu Mar 17, 2011 2:15 pm ] |
Is the "245" really 2.45? DD |
| Author: | militos [ Thu Mar 17, 2011 2:33 pm ] |
yes, that's the number I got , is it rare? let me go back to look, (man,,I have to remove that cover plate again!!), ja,ha,ha,ha. I'll be right back. |
| Author: | Doc [ Thu Mar 17, 2011 2:43 pm ] |
2.45 is the gear ratio, those are pretty common. DD |
| Author: | militos [ Thu Mar 17, 2011 2:55 pm ] |
yes! it is a 245 number. hope you can see the picture. <a href="http://s208.photobucket.com/albums/bb262/rockactualizate2/?action=view¤t=245Rearendnumber.jpg" target="_blank"><img src="http://i208.photobucket.com/albums/bb262/rockactualizate2/245Rearendnumber.jpg" border="0" alt="8 1/4 rear end ring gear nuber"></a> thanks.
| Author: | Doc [ Thu Mar 17, 2011 3:05 pm ] |
What is the gear tooth counts? Divide the number of ring gear teeth by the number of pinion teeth. 54 / 22 = 2.45 |
| Author: | Joshie225 [ Thu Mar 17, 2011 3:06 pm ] |
2.45 gears were common with V8s. They are not very fun with a slant. I hope your car is an automatic. |
| Page 1 of 2 | All times are UTC-07:00 |
