It is currently Sun Nov 29, 2026 4:05 pm
PostPosted: Tue Jan 11, 2011 10:00 pm
Car Model: Road Runner
Title says it all. Removed The Ersons 280 cam and spring set that wiped out my adjusters after a hundred miles, and installed a new 264 Comp Cam strait up. With 2.94 gears, its plenty peppy, and it gets out of its own way.
Rest of the build:
Shaved, Ported Heads with 1.77/1.40 valves
Decked block
Feather Duster Intake
3x2 Headers into a y pipe and 2.5 all the way out to a glass pack.
Idles pretty smooth and is pretty peppy. Sounds cool too.
PostPosted: Tue Jan 11, 2011 10:49 pm
6 Pack Dart
I would suggest you get one of Doc's hardened gears for your oil pump.
Richard
PostPosted: Wed Jan 12, 2011 8:54 pm
I figured I'd keep the oil thin and the RPM's shouldn't go too high with this cam.
PostPosted: Wed Jan 12, 2011 10:01 pm
6 Pack Dart
Oil is not the problem, It has to do with different hardness of cam and gear. Also how well they mesh (rough cut gear on cam) :roll:
Richard
PostPosted: Thu Jan 13, 2011 3:47 pm
My Comp 264 wiped out two OPDGs .........
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
