| another carb question https://slantsix.org/forum/viewtopic.php?t=4326 |
| Author: | Bolt [ Wed Oct 23, 2002 3:43 pm ] |
| Post subject: | another carb question |
Below is a description of a carburetor... I was wondering if this carb will bolt up to a slant intake? This is the description from the owner. This is a one (1) barrel carburetor. It is a Carter Brand; I.D. Tag still attached with the following numbers: 7040S M 4 09 A. Number on side: 6W8. Other number on Carburetor is 2316 on side. Thanks for any help! |
| Author: | Doctor Dodge (Doug Dutra) [ Fri Oct 25, 2002 10:54 pm ] |
| Post subject: | Re: another carb question |
: Below is a description of a carburetor... I was : wondering if this carb will bolt up to a : slant intake? This is the description from : the owner. : : This is a one (1) barrel carburetor. It is a : Carter Brand; I.D. Tag still attached with : the following numbers: 7040S M 4 09 A. : Number on side: 6W8. Other number on : Carburetor is 2316 on side. I do not recognize that number, do you have a PIC you can post? Most SL6 Carter 1bbls have "BBS" on the side. DD |
