| Crack??? https://slantsix.org/forum/viewtopic.php?t=43269 |
| Author: | kltcustoms.com [ Mon Jan 17, 2011 4:32 pm ] |
| Post subject: | Crack??? |
Crack?? Oh sh!t do I need to worrie about this crack? Its going into my van and will not be hopped up too much but I am kinda freaking out! This is my replacement engine for my blown one! CRAP!!! <a href="http://s269.photobucket.com/albums/jj52/kltcustoms/?action=view¤t=EngineCrack.jpg" target="_blank"><img src="http://i269.photobucket.com/albums/jj52/kltcustoms/EngineCrack.jpg" border="0" alt="Photobucket"></a> <a href="http://s269.photobucket.com/albums/jj52/kltcustoms/?action=view¤t=EngineCrack2.jpg" target="_blank"><img src="http://i269.photobucket.com/albums/jj52/kltcustoms/EngineCrack2.jpg" border="0" alt="Photobucket"></a> |
| Author: | emsvitil [ Mon Jan 17, 2011 4:36 pm ] |
I'd get a dremel and grind it out to see if it's a crack or a corrosion problem. Grind out about 1/8" and see if it stops. |
| Author: | 4speed [ Mon Jan 17, 2011 4:48 pm ] |
Looks very straight-can you see it down in the threads? Do you have a small sharp probe? |
| Author: | kltcustoms.com [ Mon Jan 17, 2011 5:21 pm ] |
To me it just looks like a flaw in the casting of the block... it does not go down into the threads...just to edge of the hole. I looked at the headgasket and it conformed with the crack...not sure what that means I am getting so frustrated with this van....one problem then another |
| Author: | speedy [ Mon Jan 17, 2011 5:45 pm ] |
You could put a puddle of some WD40 or similar light liquid on the crack and see if it seeps in |
| Author: | Fopar [ Mon Jan 17, 2011 6:10 pm ] |
Quote: You could put a puddle of some WD40 or similar light liquid on the crack and see if it seeps in
That would seem like the best thought, as you say the head gasket seems to conform to it. My thought is it is just a casting flaw.Richard |
| Author: | kltcustoms.com [ Mon Jan 17, 2011 6:12 pm ] |
Ok different view of the crack.... <a href="http://s269.photobucket.com/albums/jj52/kltcustoms/?action=view¤t=EngineCrack3.jpg" target="_blank"><img src="http://i269.photobucket.com/albums/jj52/kltcustoms/EngineCrack3.jpg" border="0" alt="Photobucket"></a> |
| Author: | 4speed [ Mon Jan 17, 2011 6:14 pm ] |
If it was mine I would not worry about it-it does not look like a stress crack. More like a flaw. |
| Author: | Jester [ Mon Jan 17, 2011 6:18 pm ] |
Looks like more of a gouge or a scratch than a crack. I wouldn't worry about it for now... |
| Author: | Reed [ Mon Jan 17, 2011 7:50 pm ] |
Quote: Ok different view of the crack....
Boy am I relieved that a picture of an engine block followed that sentence.... |
| Author: | kltcustoms.com [ Mon Jan 17, 2011 7:54 pm ] |
Heeey SHUT IT! |
| Author: | wjajr [ Mon Jan 17, 2011 9:10 pm ] |
Looks like a gouge to me, chase the bolt holes with a flat bottom tap, lube’em up, and torque her down. |
| Author: | kltcustoms.com [ Tue Jan 18, 2011 6:47 pm ] |
| Post subject: | Block ID |
Hey I was looking at this block and I see a BH on the side...what does that mean? I also have a guy who has one that his says AM ? |
