| Modifying for EFI, HELP! https://slantsix.org/forum/viewtopic.php?t=4328 |
| Author: | Dan M. [ Thu Oct 24, 2002 5:18 am ] |
| Post subject: | Modifying for EFI, HELP! |
I read the great article on EFI but need more info on modifying the stock intake. Any one have any PICS or tips? slantedsix225@aol.com |
| Author: | GTS225 [ Thu Oct 24, 2002 6:56 am ] |
| Post subject: | Re: Modifying for EFI, HELP! |
: I read the great article on EFI but need more : info on modifying the stock intake. Any one : have any PICS or tips? ************************************************* I'm in work on a conversion, and am done modifying an aftermarket intake. I had to fabricate a fixture in order to "drill" the holes in the manifold runners. It's available to borrow, but it's kinda heavy, so shipping will be a bit pricey. Where are you located? Roger GTS225@aol.com |
| Author: | Al T [ Thu Oct 24, 2002 8:35 am ] |
| Post subject: | Modifying Stock manifold for EFI *PIC* |
Have you looked at Doc's article on modifying the stock manifold in articles? He's got some pics. I've got a few pics on my site as well if you haven't seen them already . . . http://www.mopars.org/tools/bigred/efi.html ![]() ahtoews@shaw.ca |
| Author: | Dan M. [ Fri Oct 25, 2002 4:46 am ] |
: : ************************************************* : I'm in work on a conversion, and am done : modifying an aftermarket intake. I had to : fabricate a fixture in order to : "drill" the holes in the manifold : runners. It's available to borrow, but it's : kinda heavy, so shipping will be a bit : pricey. Where are you located? : : Roger Thanks Roger, I'm in Pittsburgh. I'm not sure yet, but I thought about it and most likely send it to a local shop for drilling. I'll keep your offer in mind. Thanks, Dan M. slantedsix225@aol.com |
| Author: | GTS225 [ Fri Oct 25, 2002 6:10 am ] |
: Thanks Roger, I'm in Pittsburgh. : I'm not sure yet, but I thought about it and : most likely send it to a local shop for : drilling. I'll keep your offer in mind. : Thanks, Dan M. ************************************************* OK, Dan....your call. It wold have to come from Iowa. It's just that I'm kind of a cheapskate, and when local shops started talking $120-$130 for poking six holes in my manifold, I thought it was a bit much. I ended up welding a piece of angle iron to some flat stock, "legs down", so that I could mount an intake to one of the "legs", (now at 45* to the flat stock. That way I could clamp it onto a drill press table and "drill" the holes with a .75" carbide burr. Roger GTS225@aol.com |
