| engine problems https://slantsix.org/forum/viewtopic.php?t=43286 |
| Author: | gearhead2890 [ Tue Jan 18, 2011 3:34 pm ] |
| Post subject: | engine problems |
ok so i got this 80 volare running but it has no power and will not idel i am about ready to crush it somebody said that it could be the combution computer does any one no the carb was rebuilt so i was told but it has hesitation and stubles and falls on its face on;y way it will climb a hill is in first gear pullen i r's at 10 mph |
| Author: | 4speed [ Tue Jan 18, 2011 4:27 pm ] |
OK -Do you have any repair experience? Do you have tools? Do you have a vacuum gauge? If you do what does it read at idle? I do not think a 1980 is a lean burn but to be sure do you have a photo of the engine? We can give some advice after these question. I assume that you checked all the vacuum lines coming from the carb. Have you done a tune up? |
| Author: | skurdnin [ Tue Jan 18, 2011 6:49 pm ] |
i had a similar problem with an 81. still do sorta, but the biggest difference for me was replacing the fuel lines under the hood. mine were dry rotted and sucking a lot of air. |
