Cooling Problem.....UPDATE
https://slantsix.org/forum/viewtopic.php?t=4332
Page 1 of 1
Author:  Julie Roth [ Sat Oct 26, 2002 5:30 pm ]
Post subject:  Cooling Problem.....UPDATE
Update... cooling problem
First let me say thank you for all the excellent suggestions.
I decided to implement almost all of them on my 74 Duster 225/6 - with A/C
1) cored and flushed 22" HD radiator
2) New hi flow thermostat ( 180 )
3) New water pump
4) New hoses
5) 7-blade fixed fan - ( need to get )
I am just now starting to put it back together and will let you know how it does.
I noted something curious however that I wanted to pass along to the forum.
If it is obvious or common knowledge, please excuse my ignorance.
When I got the NEW pump ( GMB ) and compared it to the OLD pump. I noted that the older pump had a 6 finned cast iron impeller. The NEW pump had a 8 - blade sheet metal impeller. Obviously the NEW pump will push more water than the original one from the car.
Julie
julie-roth@woz.org
