aftermarket fuel guage
https://slantsix.org/forum/viewtopic.php?t=43357
Page 1 of 1
Author:  slantsixbob [ Sun Jan 23, 2011 5:28 pm ]
Post subject:  aftermarket fuel guage
i installed mine today, its the proper gauge (10, 70 ohms) however the gauge will go up to where the fuel level is but then jerks to the left and back to where it was constantly.
what can cause this? is it my sending unit just not working right?
Author:  emsvitil [ Sun Jan 23, 2011 6:03 pm ]
Sounds like the sending unit.
Author:  slantsixbob [ Sun Jan 23, 2011 6:59 pm ]
alright i can give that a check, what should i be looking for when i test it? rather how should i test it?
Author:  THOR [ Sun Jan 23, 2011 9:26 pm ]
The gauge flops around because its a 12 volt gauge, and reacts to movement of the float in the tank much more radically than the factory gauge. The one in the dart does the same thing. The reason the original ones don't do that is because they are a 5 volt gauge, so they don't react nearly as fast.
Author:  slantsixbob [ Mon Jan 24, 2011 7:14 pm ]
has anyone else had this issue before?
im just curious because similar problems aren't always the same and i want to see if there are any other people who ran into this but maybe found a way around it.
Author:  kesteb [ Mon Jan 24, 2011 7:28 pm ]
Factory gauges are "dampened" so they don't wildly variate. Aftermarket gauges are much less concerned with this as most people install them for "performance" reasons and want a "true" and "accurate" reading.
Author:  slantsixbob [ Mon Jan 24, 2011 10:17 pm ]
alright thanks for the input im going to check a few things tomorrow, i have a suspicion the sending unit is in fact the culprit
Author:  slantsixbob [ Thu Feb 03, 2011 6:53 pm ]
my sending unit is in fact dead, i was wondering what part number i should use for a sending unit on my 71 scamp. i found on on summit for around 45$ but not sure if there is a major difference when buying them
