| how to tell if i've found a super six combo https://slantsix.org/forum/viewtopic.php?t=43372 |
| Author: | husker1 [ Mon Jan 24, 2011 7:30 pm ] |
| Post subject: | how to tell if i've found a super six combo |
searching in a local junk yard and found a '77 aspen with a slant 6 2 barrel. decals under hood show 225 2bbl. nothing says super six so my question is are all 2 bbl /6's super six's? thanks |
| Author: | Joshie225 [ Mon Jan 24, 2011 7:38 pm ] |
Yes, all passenger cars and light trucks with 2bbl carbs are considered to be Super Sixes. They were introduced for the 1978 model year. |
| Author: | husker1 [ Mon Jan 24, 2011 7:55 pm ] |
will that intake/exhaust bolt on to a '71 cylinder head? |
| Author: | Reed [ Mon Jan 24, 2011 7:59 pm ] |
Not to toot my own horn, but you need to read THIS |
| Author: | husker1 [ Mon Jan 24, 2011 8:12 pm ] |
Thank you, looks like plenty of info. |
| Author: | Jester [ Mon Jan 24, 2011 9:19 pm ] |
Quote: Not to toot my own horn, but you need to read THIS
Toot that horn... it's probably the most viewed article on the site |
| Author: | Reed [ Mon Jan 24, 2011 10:28 pm ] |
Quote: Quote: Not to toot my own horn, but you need to read THIS
Toot that horn... it's probably the most viewed article on the site Anyway, it still answers most all of the questions about a Super Six upgrade. The only things I would change would be to add some discussion of adding a Super Six to a van and to add a recommendation that people try and use cable style kickdown linkages since the factory correct ones are getting scarce. A discussion of how to make your own two barrel intake would also be helpful. |
| Author: | Jester [ Tue Jan 25, 2011 2:11 am ] |
Yep, discussing a Lokar and Bouchillon kickdown would be great, maybe even a link on how to set them up properly. Also some automatic choke options. It's nice to have everything you need on one page. Oh yeah, can't forget the part #'s of manifold hardware |
| Author: | Wesola78 [ Tue Jan 25, 2011 6:06 am ] |
Toot that horn Reed! |
| Author: | rooster [ Tue Jan 25, 2011 6:54 am ] |
Extreamly nice article. Future update should possiably include mention of aussie gaskets, they tell me they are sweet. but by all means, toot that horn sir. rooster |
| Author: | coconuteater64 [ Tue Jan 25, 2011 11:59 am ] |
Toot! Toot! The Reed Express is passing through! Excellent article, but I second the recommendation on the Aussie gaskets. They are real problem solvers! |
