lightened dipstick
https://slantsix.org/forum/viewtopic.php?t=4338
Page 1 of 1
Author:  johnny [ Mon Oct 28, 2002 9:02 am ]
Post subject:  lightened dipstick
OK, this is weird. but my 73 Dart (225 slant 6) has a dipstick that looks as if the end has been chewed off _ all the marks are missing. the socket is loose in the block, so the stick could move around...anybody else ever heard of this/have it happen?
jfalcone@easystreet.com
Author:  dschumers [ Mon Oct 28, 2002 7:16 pm ]
Post subject:  Sounds like a rod knock
When I fired up my good motor, I heard a rattle coming from the bottom end. I noticed the top of the dipstick wiggling and pulled it out. Noise went away. I had to bend the stick a little to keep it out of the crank. Dennis
slantzilla@excite.com
Author:  Doctor Dodge (Doug Dutra) [ Mon Oct 28, 2002 8:49 pm ]
Post subject:  Re: dipstick tips...
: OK, this is weird. but my 73 Dart (225 slant 6)
: has a dipstick that looks as if the end has
: been chewed off _ all the marks are missing.
: the socket is loose in the block, so the
: stick could move around...anybody else ever
: heard of this/have it happen?
The best "dipstick tip" I can give is to keep it away from the crank!
I can't count all the broken-off dipstick tips I have found in the bottom of a well used SL6 oil pans.
Yes, it's a somewhat common problem, that dipstick is no match for 76lbs of spinning SL6 crankshaft.
Author:  sandy in nova scotia [ Tue Oct 29, 2002 2:21 pm ]
Post subject:  Re: Sounds like a rod knock
I have found they break off nice and clean at the full mark! If someone put a manifold on it 9 times out of 10 the dipstick tube gets bent and into the crank it goes.
One of the lttle quirks of a slant goes along with crackd exhaust manifolds well!
Sandy
sandy.colter@ns.sympatico.ca
Author:  bud L. [ Tue Oct 29, 2002 8:28 pm ]
: I have found they break off nice and clean at
: the full mark! If someone put a manifold on
: it 9 times out of 10 the dipstick tube gets
: bent and into the crank it goes.
: One of the lttle quirks of a slant goes along
: with crackd exhaust manifolds well!
: Sandy
My wife's '95 LHS has a cool dipstick I'd like to adapt to a sl/6. It's a cable with a crimped-on little torpedo shaped slug. Very readable, flexible, with a good sized yellow-colored t-handle on the end.
fglmopar@aol.com
