It is currently Fri Aug 28, 2026 3:55 pm
 Post subject: vacuum porting help
PostPosted: Thu Jan 27, 2011 10:12 pm
hi guys need to know where the best spot is on a 225 cliffy 4bbl, with a holley 600cfm vac sec 4160 carb, 1" aluminium spacer/adapter with a vacuum nipple on the front, motor is bone stock aside from the intake and 4bbl, to either drill and tap a fitting, or use an existing port for a vacuum gage in cockpit, and for power brakes. i have heard that you don't want to use the #6 runner for power brakes as it tends to lean out that cylinder,
as always thanks for the help guys,
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Thu Jan 27, 2011 10:28 pm
The simplest is to and tap the 1" spacer.
PostPosted: Thu Jan 27, 2011 10:43 pm
There is nothing wrong with using the #6 runner for the power brakes. Chrysler did it that way. The flow is not that high. Having the PCV on a single cylinder is not a good idea, but the brake booster is fine.
PostPosted: Fri Jan 28, 2011 8:34 am
awesome thanks guys as always great advice,
mike
Users browsing this forum: Amazon [Bot], Bing [Bot] and 17 guests
