| vacuum porting help https://slantsix.org/forum/viewtopic.php?t=43403 |
| Author: | Volare4life [ Thu Jan 27, 2011 10:12 pm ] |
| Post subject: | vacuum porting help |
hi guys need to know where the best spot is on a 225 cliffy 4bbl, with a holley 600cfm vac sec 4160 carb, 1" aluminium spacer/adapter with a vacuum nipple on the front, motor is bone stock aside from the intake and 4bbl, to either drill and tap a fitting, or use an existing port for a vacuum gage in cockpit, and for power brakes. i have heard that you don't want to use the #6 runner for power brakes as it tends to lean out that cylinder, as always thanks for the help guys, -Mike |
| Author: | Aggressive Ted [ Thu Jan 27, 2011 10:28 pm ] |
The simplest is to and tap the 1" spacer. |
| Author: | Joshie225 [ Thu Jan 27, 2011 10:43 pm ] |
There is nothing wrong with using the #6 runner for the power brakes. Chrysler did it that way. The flow is not that high. Having the PCV on a single cylinder is not a good idea, but the brake booster is fine. |
| Author: | Volare4life [ Fri Jan 28, 2011 8:34 am ] |
awesome thanks guys as always great advice, mike |
