A 518 OD tranny
https://slantsix.org/forum/viewtopic.php?t=4346
Page 1 of 1
Author:  Richard Holtsclaw [ Wed Oct 30, 2002 9:55 am ]
Post subject:  A 518 OD tranny
Have got a 64 Fury 4 door and am planning to stick in a /6 from a 74 valiant. number of questions. First, just read an article on swapping in a A-518 auto OD into a 340 Duster and wondered if it would work for the slant 6, second, I read several questions on obtaining duel exhaust manifolds but found no info on getting some for myself and would definatly like them if for no other reason then making my wife mad. Tanks, Richard
jkholtsc@wsuhub.uc.twsu.edu
Author:  Dave Clement [ Wed Oct 30, 2002 3:36 pm ]
Post subject:  Re: A 518 OD tranny
: Have got a 64 Fury 4 door and am planning to
: stick in a /6 from a 74 valiant. number of
: questions. First, just read an article on
: swapping in a A-518 auto OD into a 340
: Duster and wondered if it would work for the
: slant 6, second, I read several questions on
: obtaining duel exhaust manifolds but found
: no info on getting some for myself and would
: definatly like them if for no other reason
: then making my wife mad. Tanks, Richard
The A518 and A500 OD trannies only came with small block v8 bellhousing bolt pattens. You have to get an adapter to allow it to bolt to a slant 6.
Dave Clement
Hot-Rod 6
david.clement@verizon.net
Author:  Doctor Dodge (Doug Dutra) [ Wed Oct 30, 2002 7:16 pm ]
: I have read several questions on
: obtaining dual exhaust manifolds but found
: then making my wife mad. Thanks, Richard
Below is a link to more info on cast iron dual exhaust manifolds for the SL6
Dutra Duals Info.
Author:  Chuck Rivers [ Wed Oct 30, 2002 8:38 pm ]
The contact data for the Dutra Duals is also in the online parts database.
Chuck
sl6@omnipages.com
Author:  Dart270 [ Thu Oct 31, 2002 9:43 am ]
I have done this OD auto swap with an A500 into my '68 Dart. You should have more room in your Fury, so an A518 might not be too tough either, although it's probably not necessary. You need an adapter plate from a pre-'68 PU or van with a 727 and Slant 6. You'll have to fab a new lower X-member and rear mount, shorten driveshaft, and some other odds and ends.
It's some work, but it works pretty well. Be advised that you can't get very high stall converters for the lockup tranny's (which mine is).
Author:  andyf [ Thu Apr 22, 2004 2:29 pm ]
I have the first of my new design /6 to 727 billet aluminum adapter finished up and am doing some final test fittings. I should have info on the website in another month or two.
