Slant Six Forum https://slantsix.org/forum/ |
4-pin ECU: Pass/fail or degrees of failure? https://slantsix.org/forum/viewtopic.php?t=43462 |
Author: | krytellan [ Mon Jan 31, 2011 6:26 pm ] |
Post subject: | 4-pin ECU: Pass/fail or degrees of failure? |
Just another question about my new toy. So, this Chrysler ECU system is rather new to me, and a bit more basic than ECU's I have experience with. As some of you know I recently acquired Murphy, a 1980, 225, 1 bbl. I have been upgrading all that I can in the past weeks and my current curiosity brings me to said ECU. Do ECU's degrade over time or is it a yes/no object? If the ECU is stock, is there any benefit to replacing it if the car runs normally? I get the sense it's normal for the ECUs to puke some now hard gluey substance... I have that, is it bad? Also, is there a benefit to replacing a working coil if it is perhaps original? |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
