Slant Six Forum https://slantsix.org/forum/ |
dry rocker mystery https://slantsix.org/forum/viewtopic.php?t=43483 |
Author: | jimkiehn [ Tue Feb 01, 2011 12:11 pm ] |
Post subject: | dry rocker mystery |
i have a 1968 slant six and very low compression. the rocker assembly was dry too so i pulled the head. the oil holes in the block to the head were dry also. i pulled a piston the rings were dry. it was a miracle this motor ran at all! i blew air through one of the oil holes in the block and i heard it escaping at the rear of the block. is the rear oil seal blown and thus not pressurizing the left side of the motor which supplies the head? i never saw this before. anybody got a slant six for sale? i'm in oklahoma city. jim |
Author: | Doc [ Tue Feb 01, 2011 12:54 pm ] |
Post subject: | |
There is a good chance that the engine has worn cam bearing and that makes it hard for the oil to reach the rocker arms. How many miles are on this engine? DD ![]() |
Author: | jimkiehn [ Tue Feb 01, 2011 1:59 pm ] |
Post subject: | dry rockers |
wow ! thanks you're the first person who has said anything. and the graphic is really helpful too. the engine is old for sure. bored well over stock. i guess next thing is to pull the thing and make sure i can bench pressurize the situation. apply some kind of external oil pressure and see if it can reach the oil holes. i guess i could just put the pump back on and crank it also. heave ho! jim |
Author: | Doc [ Tue Feb 01, 2011 2:26 pm ] |
Post subject: | |
Better yet, go under the engine and pull-out the pressure sending unit or oil pump's releif valve, install a hose connection fitting into the tapped hole and apply oil pressure thru that connection. DD ![]() ![]() |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
