| Carter Carb cfm https://slantsix.org/forum/viewtopic.php?t=43488 |
| Author: | 62 alum [ Tue Feb 01, 2011 5:55 pm ] |
| Post subject: | Carter Carb cfm |
I have searched the carter web site and also this one and found a lot of info. on the 3083s carburetor but nothing on the cfm rating. Just curious, we are in a blizzard here in the mid-west with time on my hands |
| Author: | olafla [ Sat Feb 05, 2011 10:54 pm ] |
The Carter 3083S is the 4 bbl. used on the Hyper Pak, and as far as I know also on the first high-performance 273. Quote: Specific airflow ratings for early AFBs are not readily available since Carter did not flow rate their products in those days. However, judging by venturi and throttle-bore diameters, it appears that the flow range of original AFBs is between 450 and 625 cfm, with variations dependent upon the original application.
There is an approximation of the flow, based upon the size of the bore and venturi diameters, at buickperformance.com.Olaf. |
| Author: | 62 alum [ Sun Feb 06, 2011 2:36 pm ] |
Olaf thank you for the info. I hope the metering rods and jets are ok and I can have it rebuilt with just gaskets. It has been setting in storage for 40 years |
| Author: | olafla [ Sun Feb 06, 2011 11:20 pm ] |
I have a couple of other AFB links here too: www.mymopar.com/downloads/carterafbtuning.pdf Here is the imperialclub.com's info on the AFB. Here is a link to a thread, that among other good AFB info, lists the jet and metering rod sizes and numbers for Carter vs. Edelbrock, over at v8buick.com BTW, 40 years is an excellent age for a carb! Olaf. |
