| carb blowback https://slantsix.org/forum/viewtopic.php?t=4349 |
| Author: | zac smith [ Thu Oct 31, 2002 3:28 pm ] |
| Post subject: | carb blowback |
My /6 is a hard cold starter. Often before it starts it will "diesel" and blow smoke and stuff back through the carb. I think it actually might be turning backwards when this happens. It WILL eventually start, but always takes a while, I usually have to manually open the choke, an I sometimes run through a battery first. I've got plenty of fuel at the carb, and the spark seems strong at the distributor, and at every plug I check. It runs great when it starts, and hot starts are very easy, if I don't give it too much gas. I'm out of ideas.... zac zac_smith@hotmail.com |
| Author: | Chuck Rivers [ Thu Oct 31, 2002 7:10 pm ] |
| Post subject: | Re: carb blowback |
: My /6 is a hard cold starter. Often before it : starts it will "diesel" and blow : smoke and stuff back through the carb. I : think it actually might be turning backwards : when this happens. It WILL eventually start, : but always takes a while, I usually have to : manually open the choke, an I sometimes run : through a battery first. : : I've got plenty of fuel at the carb, and the : spark seems strong at the distributor, and : at every plug I check. It runs great when it : starts, and hot starts are very easy, if I : don't give it too much gas. I'm out of : ideas.... : : zac Your valves may be sticking when cold. Try putting some Maevel Mystery Oil in the crankcase and see if that helps. Works great on sticky valves. Chuck sl6@omnipages.com |
