| Dual master cylinder upgrade https://slantsix.org/forum/viewtopic.php?t=43506 |
| Author: | valiant effort [ Thu Feb 03, 2011 7:57 am ] |
| Post subject: | Dual master cylinder upgrade |
Hi folks, I am going to upgrade my single master cylinder on a 64 valiant to a dual master. What year of car makes the easiest transition. I know there is replumbing to be done but mostly I just need the simplest change over. Any help is appreciated...thanks Mark |
| Author: | hellion_locdogg [ Thu Feb 03, 2011 5:02 pm ] |
Depending on where you buy your parts most MCs are listed for what the do i.e. 4 wheel manual drum or power front disk rear drum. Just get the one that matches your set up. I went with manual KH front disk and rear drums so that was the master I went with and you'll need a proportioning valve too. Check out Rock auto... |
| Author: | mpgFanatic [ Tue Mar 15, 2011 12:34 am ] |
| Post subject: | Re: Dual master cylinder upgrade |
Quote: I am going to upgrade my single master cylinder on a 64 valiant to a dual master. What year of car makes the easiest transition. I know there is replumbing to be done but mostly I just need the simplest change over. Any help is appreciated...thanks Mark
OK, I'm a month late here... so I assume you've discovered this article by now. But just in case not...http://earlycuda.org/tech/dualmaster.htm - Erik |
| Author: | valiant effort [ Wed Mar 16, 2011 11:09 am ] |
| Post subject: | brakes |
Erik, Thanks so much. With all the other things im doing with the car I had not gotten around to this yet. Your article will make it much easier...Mark |
