| suspension question https://slantsix.org/forum/viewtopic.php?t=43570 |
| Author: | 1974duster [ Tue Feb 08, 2011 12:58 pm ] |
| Post subject: | suspension question |
so i have got my torsion bars and my edlerbrock ias shock and i am going to rebuild the front end do i need to get new clips for the torsion bars?? also i was wondering what would be a good size sway bar |
| Author: | 2 Darts [ Fri Mar 04, 2011 8:42 pm ] |
| Post subject: | Re: suspension question |
Quote: so i have got my torsion bars and my edlerbrock ias shock and i am going to rebuild the front end do i need to get new clips for the torsion bars?? I've re-used intact clips with no problem. Make sure clip sits in groove fully. (True if using new or used clips.)Quote: also i was wondering what would be a good size sway bar I'm using a combination 1¼" front bar and a 1" rear bar. If you're not going to install a rear bar, I recommend nothing larger than a 1 1/8" bar. This is assuming you have the factory sway bar tabs on the LCA.
