| who sells high comp pistons https://slantsix.org/forum/viewtopic.php?t=43576 |
| Author: | USAJon [ Wed Feb 09, 2011 7:25 am ] |
| Post subject: | who sells high comp pistons |
looking to figure our $$$ for a spare build. who makes high comp pistons with turbo/thin rings for a slant. I talked to Venolia they said $79.95 each to my specs no rings. anyone else out there make good high comp pistons? |
| Author: | Doc [ Wed Feb 09, 2011 2:27 pm ] |
It is really hard to beat the Wiseco / K1 piston & con rod set-up. (7 inch c to c connecting rod) As far as high compression factory size SL6 pistons... you will need to have them custom made. DD |
| Author: | USAJon [ Wed Feb 09, 2011 2:46 pm ] |
whats up with 87-88mm turbo pistons..? |
| Author: | USAJon [ Wed Feb 09, 2011 2:50 pm ] |
Quote: It is really hard to beat the Wiseco / K1 piston & con rod set-up. (7 inch c to c connecting rod)
that looks like aprox $1000 delivered...
| Author: | slantzilla [ Wed Feb 09, 2011 3:46 pm ] |
I had Ross make a set of thick deck 3.5" bore thin ring pistons. They were right at $120 each with pins, and another $240 for nitrous rings. That was buying 8 too. Most any piston maker will do pistons to your specs. Make sure to ask prices BEFORE you order though. Ross charged $40 a piston to move the pin hole .100". I thought that was somewhat excessive when it was a custom piston anyway. |
| Author: | onemoparman [ Wed Feb 09, 2011 6:02 pm ] |
Quote: It is really hard to beat the Wiseco / K1 piston & con rod set-up. (7 inch c to c connecting rod) As far as high compression factory size SL6 pistons... you will need to have them custom made. DD what compression would that bring a stock uncut head and block too doc? and how much does the combo cost? |
| Author: | Doctor Dodge [ Wed Feb 09, 2011 9:18 pm ] |
Quote: Quote: It is really hard to beat the Wiseco / K1 piston & con rod set-up. (7 inch c to c connecting rod)
Getting that looks like aprox $1000 delivered...DD DD |
