Any creative ideas to plug distributor hole?
https://slantsix.org/forum/viewtopic.php?t=43627
Author:  65CrewCabPW [ Sun Feb 13, 2011 1:02 pm ]
Post subject:  Any creative ideas to plug distributor hole?
I'm putting EDIS on my slant and since I don't need the dist sitting down there, i was wondering if anyone had any great ideas for plugging it off without the distributor in place, and sealed to keep dirt / water / etc out?
Author:  slantzilla [ Sun Feb 13, 2011 1:51 pm ]
Freeze plug or rubber expansion plug.
Author:  Reed [ Sun Feb 13, 2011 3:03 pm ]
You might be able to use a distributor hold down clamp and fashion a flat plate plug to go over/in the hole. Otherwise, ditto on on the rubber expansion plug.
Author:  65CrewCabPW [ Sun Feb 13, 2011 6:15 pm ]
Well, Duuhhh, as Homer would say. Great idea!
thanks!
Author:  1974duster kev [ Sun Feb 13, 2011 8:38 pm ]
Weld that bad boy shut!
Kev
Author:  1980volare [ Mon Feb 14, 2011 2:37 pm ]
how about a block off plate/ mount for the coil pack?
Author:  Rick Covalt [ Mon Feb 14, 2011 3:09 pm ]
Post subject:  Distributor
Take a junk points type Distributor housing( Or any that you have laying around) and cut it off and weld a small aluminum plate over the end. Bolt it in with the normal hold down bolt.
