| no compression, rocker arm ass. https://slantsix.org/forum/viewtopic.php?t=43644 |
| Author: | slant6proud [ Mon Feb 14, 2011 2:09 pm ] |
| Post subject: | no compression, rocker arm ass. |
I really hope someone can help.I have an 87 p/u with a slant six, burned a valve so I replaced the head with a used one got it together and I have no compression in #1 2 or 4. If I take the rockerarm ass. off i have comp. in all six, repeat same prob. Both heads have the same casting #'s Tried switching the rockerarm ass. off original head I tighten rockerarm ass. from middle to both ends even at 5 ft lbs no comp. no shims available[/i] |
| Author: | emsvitil [ Mon Feb 14, 2011 2:19 pm ] |
Did you leave enough time for the hydraulic valve lifters to bleed down? |
| Author: | Doc [ Mon Feb 14, 2011 2:23 pm ] |
Are all the valve stem heights even? (Put a straight edge across the stem tips) DD |
| Author: | slant6proud [ Mon Feb 14, 2011 6:03 pm ] |
the engine has been together for almost 2 weeks so lifter position is not an issue I just ran a straight edge across the top of the valves #1 Int. .007 #3 Int. .007 #4 Int. .007 #5 Int. .007 #6 Int. .002 Thank you for such a quick response, hope to hear from you again soon with another response, I have tried everything I can think of so I am willing to try about anything, especially /6 experts |
| Author: | Doctor Dodge [ Mon Feb 14, 2011 7:12 pm ] |
Buy a set of rocker arm shaft shims... File-down (grind) the outer edges of the shims to reduce the chance of cracking the cast iron support tower, (a wedge is a powerful tool DD http://store.440source.com/Rocker-Shaft ... /127-1020/
| Author: | slant6proud [ Tue Feb 15, 2011 6:22 am ] |
What should the clearance or difference be, shim all 7 connections? And if I shim all 7 wouldn't that reduce the amount of lift on the cylinders that do have compression? Thanks again for your expert knowledge |
