Slant Six Forum https://slantsix.org/forum/ |
1969 225 https://slantsix.org/forum/viewtopic.php?t=43720 |
Author: | 78mopar [ Sat Feb 19, 2011 12:12 pm ] |
Post subject: | 1969 225 |
any idea if a 69 225 will fit in a 78 volare or do i have to change the pan? |
Author: | DusterIdiot [ Sat Feb 19, 2011 2:36 pm ] |
Post subject: | Yes if... |
If it is truly a 1969 block/crank and from a 1969 Dart/Valiant it should go right in without much fanfare. -D.Idiot |
Author: | 78mopar [ Sat Feb 19, 2011 3:14 pm ] |
Post subject: | |
its out of a 1969 satellite |
Author: | DusterIdiot [ Sat Feb 19, 2011 6:38 pm ] |
Post subject: | Check... |
You should be able to make this swap...assuming it's the original engine or if replaced, the previous owner used a 1968+ engine...if someone decided to put a 1967 or earlier motor and tranny in it then it won't work... Have you looked at the ID pad near the #1 spark plug and alternator bracket to see what numbers it has. -D.Idiot |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
