| pitman arm and idler arm https://slantsix.org/forum/viewtopic.php?t=43725 |
| Author: | Flatblack77 [ Sat Feb 19, 2011 3:15 pm ] |
| Post subject: | pitman arm and idler arm |
i am trying to get the parts together for my front end rebuild. do i need an idler arm and pitman arm? i already got the pitman arm and now i am wondering if i need the idler arm as well. thanks. car is a 1977 plymouth volare 2 door custom with slant six. should i get new bushings as well? |
| Author: | Dart270 [ Sun Feb 20, 2011 5:21 am ] |
Hard to tell unless you check play in idler and bushings. Most likely, yes. Idler arm usually wears out before the pitman arm. Lou |
| Author: | Flatblack77 [ Mon Feb 21, 2011 6:50 am ] |
| Post subject: | suspension |
thanks lou. |
