| need valve cover that won't leak...Please help!! https://slantsix.org/forum/viewtopic.php?t=43732 |
| Author: | toedfe [ Sun Feb 20, 2011 11:14 am ] |
| Post subject: | need valve cover that won't leak...Please help!! |
I am looking for a good quality aftermarked valve cover that will not leak. Any leads or suggestions will be greatly appreciated. I know about overtightening and straightening out the contact surface but mine is so damned old and worn out and so am I. There has to be better way. Thanks Frank |
| Author: | hantayo13 [ Sun Feb 20, 2011 11:18 am ] |
nada ....there are no good aftermarket valve coversfor slant....find a good used stock one...either paint and send it to chrome shop if you a chromed one |
| Author: | Joshie225 [ Sun Feb 20, 2011 11:41 am ] |
The cast aluminum Offy valve cover will be considerably stronger and will lighten your wallet significantly. Also, you have to do some custom work to use a PCV valve; it's been discussed at length. |
| Author: | SlantSixDan [ Sun Feb 20, 2011 1:55 pm ] |
Quote: nada ....there are no good aftermarket valve coversfor slant
Sure there is: the Offenhauser aluminum item. But a stock valve cover in good condition with a good gasket seals up just fine. The cheap chrome aftermarket ones are Chinese garbage, though.
| Author: | olafla [ Sun Feb 20, 2011 6:11 pm ] |
There is also a brand new aluminum cover from aussiespeed.com, but I do not know anything about availablility in USA yet. They come in raw, polished and black painted versions. You can also take a look at the aircraft quality silicone rubber valve cover gaskets from realgaskets.com, mentioned in this thread. Olaf. |
| Author: | hantayo13 [ Sun Feb 20, 2011 7:37 pm ] |
correct me if I am wrong ...but the offy alum one needs work to work right |
| Author: | Fopar [ Sun Feb 20, 2011 8:43 pm ] |
I have a Clifford (copy of Offy) and I used 2 neoprene glued together with contact cement. You will need longer cap screws or 1/4 20 bolts. Richard |
