| Sparkplugs,brand heatrange etc. https://slantsix.org/forum/viewtopic.php?t=43748 |
| Author: | Philip's66 [ Mon Feb 21, 2011 3:13 pm ] |
| Post subject: | Sparkplugs,brand heatrange etc. |
What plugs do you recommend for a '66 225? I am currently bringing my mother's Dart back to life. Going thru carb Carter BBD, Fuel pump, Distributor. It has Autolites in it -They look good but I want everything fresh when I put it back together. I thought I read somewhere the washer on the plug should be removed if the motor has the Oil tubes around the plug. Is this correct & why? [/img] |
| Author: | 65CrewCabPW [ Mon Feb 21, 2011 6:08 pm ] |
Anything but Autolites. Seriously, for some reason, they just do not ignite anything. I have great success with Champion or denso... champion now makes a truck plug and a heavy duty plug that should last a long time. Dunno if they make it for the SL6, though. My next attempt at plugs is to check out E3's and / or Halo plugs. |
| Author: | lowbudget [ Mon Feb 21, 2011 8:49 pm ] |
NGK's Do a search on forum as this subject has been discussed many times. |
| Author: | Philip's66 [ Tue Feb 22, 2011 7:12 am ] |
Thanks found the info I needed .I am glad I came across this site. Wish i would have found it earlier!!! |
| Author: | SlantSixDan [ Tue Feb 22, 2011 2:12 pm ] |
Tune-up parts and technique suggestions, including spark plugs, in this thread. |
| Author: | Philip's66 [ Tue Feb 22, 2011 2:28 pm ] |
Thank You Very Much.! I really appreciate this info!!. This has helped me tremendously and explains some of the issues I have had with this vehicle. I will continue to search thru here to find out more stuff I did not know . Thanks Again.[/img] |
| Author: | slantfin [ Tue Feb 22, 2011 4:18 pm ] |
Welcome 66. There is a gold mine of information on this site. If you have time, check out the general-info articles, and also the FAQ's at the top of each section. |
