| Rebuild question https://slantsix.org/forum/viewtopic.php?t=43750 |
| Author: | Rick Covalt [ Mon Feb 21, 2011 7:10 pm ] |
| Post subject: | Rebuild question |
Ryan and I disassembled his 4 speed OD this evening and I have a question. The spacer tube inside the cluster gear is not solid. It is split end to end. I noticed that on each end of the tube there is a noticeable gap. The center about 4 inches of the tube is tight together. But on each end it is opened up some. Is this normal? Something to worry about. This is just a spacer if I'm not mistaken and can't see how it would have been spread apart in normal operation. Want to start reassembly tomorrow. Thanks, Rick |
| Author: | Joshie225 [ Mon Feb 21, 2011 7:36 pm ] |
#50?
| Author: | Rick Covalt [ Tue Feb 22, 2011 3:55 am ] |
| Post subject: | Correct |
Yes #50 |
| Author: | Rick Covalt [ Tue Feb 22, 2011 11:49 am ] |
| Post subject: | Bump |
Plan to start going back together in about 2 hours. Any opinions? Rick |
| Author: | Greg Ondayko [ Tue Feb 22, 2011 2:16 pm ] |
Rick, I cant rembember how mine looked when I had them apart. Sorry. But if it's a real concern, Just weld the opened ends toghter and grind / file them down smooth. Greg |
| Author: | Rick Covalt [ Tue Feb 22, 2011 2:59 pm ] |
| Post subject: | Thanks |
Thanks Greg, I wasn't really worried. I just didn't know if I was supposed to be. Rick |
| Author: | slantfin [ Thu Feb 24, 2011 7:36 pm ] |
| Post subject: | Wha happen? |
So did you assemble as is? |
| Author: | Rick Covalt [ Fri Feb 25, 2011 4:08 am ] |
| Post subject: | plans changed |
Well, Plans changed and I didn't get to it as quickly as I thought, but I am going to install it as is. I cant see any reason not too. Rick |
| Author: | Romeo Furio [ Fri Feb 25, 2011 4:25 pm ] |
Rick, How about giving Jammie Passion a call,570-401-8949. I am sure he will be able to fill you in on all the 4 speed info you want. Good guy and willing to help. + he is a fellow PAer not toooo far from you. |
| Author: | Rick Covalt [ Fri Feb 25, 2011 6:01 pm ] |
| Post subject: | All is well |
I already assembled it. I'm sure it will be Ok. It is only a spacer. But the funny thing (Not really so funny) was that when I packed all the new bearings into my cluster gear, guess what I had left over. 1 bearing!! Rick |
| Author: | slantfin [ Sat Feb 26, 2011 6:56 am ] |
I tend to refer to that as "practice". |
| Author: | Romeo Furio [ Sat Feb 26, 2011 7:29 am ] |
I call it oldtimers,,,,,,,,,, ??/ /what was I typing ?? Were am I ??? This is a funny looking television,the remote only has 2 buttons and some kind of wheel?............................... |
| Author: | Rick Covalt [ Sat Feb 26, 2011 7:46 am ] |
| Post subject: | Not alone |
It is good to know that we are not alone!! Rick |
| Author: | wjajr [ Sat Feb 26, 2011 9:50 am ] |
Romeo Furio: Quote: I call it oldtimers,,,,,,,,,, ??/ /what was I typing ?? Were am I ???
Space Command Tuning baby:This is a funny looking television,the remote only has 2 buttons and some kind of wheel?............................... http://en.wikipedia.org/wiki/File:Zenit ... er_600.jpg Morehere |
| Author: | Romeo Furio [ Sat Feb 26, 2011 1:16 pm ] |
It truly amazes me the things you come up with....... |
