It is currently Sat Nov 14, 2026 3:19 pm
 Post subject: engine size
PostPosted: Sat Mar 05, 2011 10:42 am
How do we tell the eng size by looking at a slant 6 ? Thank's SMOKEY. :(
PostPosted: Sat Mar 05, 2011 4:47 pm
under # 1 plug on top of block , behind alt bracket ...it is stamped there
PostPosted: Sat Mar 05, 2011 7:53 pm
Thank you. SMOKEY.
PostPosted: Sun Mar 06, 2011 4:31 am
If by chance the information has been removed from top of block below #1, you can narrow it down by measuring the short hose between head and water pump. If the short hose is about one & one half inch long you have a 170 ci, and if it is about three inches long a 198 or 225 ci.
