| Has Anyone Dynoed Their Street Engine? https://slantsix.org/forum/viewtopic.php?t=43787 |
Page 1 of 2 |
| Author: | 63Dart [ Thu Feb 24, 2011 6:12 pm ] |
| Post subject: | Has Anyone Dynoed Their Street Engine? |
Hi All, I'm curious how much power folks are putting out on their *street* /6 motors. I have no idea what mine puts out - but I know that I can go 100MPH up Altamont pass (not saying I've ever done this, BTW). . . without flooring the gas pedal. . . I may end up putting it on a dyno - I really have no idea what it puts out - BUT I can tell you that Doug truly earned the name "Guru" on this build!!! |
| Author: | turbo66valiant [ Fri Feb 25, 2011 11:27 am ] |
Sure, right here!! http://www.youtube.com/watch?v=O4Kl9MBr15o |
| Author: | slantfin [ Fri Feb 25, 2011 1:00 pm ] |
That sounds like an F 18 taking off. |
| Author: | DAlexanderW [ Fri Feb 25, 2011 3:12 pm ] |
turbo66valiant, What's your engine recipe? what type of gas do you burn? |
| Author: | Romeo Furio [ Fri Feb 25, 2011 4:39 pm ] |
| Post subject: | Dyno |
About 10 years ago I did up a 225 (street car,standard bore) auto with 3.23 gears. The engine had a .100 milled head, standard valves, mild port work, Clifford intake, 500 afb, Clifford shorty headers,2 1/2 single exhaust with a Flowmaster 40, Petronix ignition. Made 153 rear wheel hp. The guy(running the dyno) said guesstamation 200-208 at the fly wheel. So ?? who knows just a ball park figure. |
| Author: | Exner Geek [ Fri Feb 25, 2011 7:01 pm ] |
With 10:1 compression, Mike Jeffrey street ported head with 289 Ford valves, Racer Brown ST-14 cam 266 degrees .485 lift, a 500CFM Holley 2BBL, and clifford shorty headers mine made 186HP at the rear wheels. The same engine with a Racer Brown ST-22 cam 276 degrees .505 lift and a Demon 525CFM four barrel made 214HP. This is with an OD 4 speed where the chassis losses aren't as high as with an automatic. |
| Author: | Valleyant [ Fri Feb 25, 2011 8:21 pm ] |
Curious were you using the stock cam, Romeo? 63Dart just to give you a baseline, my stock '72 Valiant 225/904 with 2.76er's out back and holley 1920 put 80HP and 140 LB-FT Torque to the wheels. Good enough for a 17.8 @ 75 MPH in the quarter mile. |
| Author: | Charrlie_S [ Sat Feb 26, 2011 4:42 am ] |
My street/strip 170 in a 66 Cuda, dynoed at 358 ft/lbs and 204 hp, at the wheels with the nitrous on. Portable dyno at Pittsburg Raceway, 2006. |
| Author: | Shaker223 [ Sat Feb 26, 2011 5:02 am ] |
Best dyno with a bad miss... turbo 6 = 296rwhp/381hp |
| Author: | Romeo Furio [ Sat Feb 26, 2011 7:37 am ] |
Yes stock cam, 340 valve springs |
| Author: | Romeo Furio [ Sat Feb 26, 2011 7:42 am ] |
I remember that Charlie, Didn't you hurt something in the car after that ? Man , That was 5 years ago already, I think that was the last year for slant racing with Chrysler Classic Events..? |
| Author: | Charrlie_S [ Sat Feb 26, 2011 10:54 am ] |
Quote: I remember that Charlie, Didn't you hurt something in the car after that ?
Yes, I had a nitrous "sneeze", on the run against Ron Hamby, and hurt 3 pistons. Don't really know why. Put three piston/rod assy in from another motor, and that's the way it is today.
| Author: | slantzilla [ Sat Feb 26, 2011 10:24 pm ] |
The race shop I used to work at is installing a new Superflow engine dyno. The owner is begging me to bring out my engine so he can make a few pulls. |
| Author: | Rug_Trucker [ Sun Feb 27, 2011 9:33 am ] |
Stock valves, cam, running pig rich blowing black smoke. I drilled the jets on a BBD..........not good. 89HP at the wheels on a portable dyno at the Music City show. I ran 10.58's in the 1/8th @ 59 mph before the pig rich carb. |
| Author: | slantzilla [ Sun Feb 27, 2011 11:15 am ] |
Mike J has spent a ton of time on Bogner's dyno with his stocker motor. He has found that most of the time the stock jets in a BBD are rich anyway. |
| Page 1 of 2 | All times are UTC-07:00 |
