Coil Recommendation Request
https://slantsix.org/forum/viewtopic.php?t=43791
Page 1 of 1
Author:  J. Goodman [ Fri Feb 25, 2011 7:29 am ]
Post subject:  Coil Recommendation Request
My 64 Dart (225/904 combo) currently uses a Pertronix Ignitor in place of points. I can't tell what brand the coil is since all labels, etc. are long gone. If you are using the same setup, what coil do you use? I found a Pertronix 40011 Flame Thrower Ignition Coil at Summit for $30.95. It has a primary resistance value of 1.50 ohms. Rock Auto sells a few different coils for our engines. Would one of those work just as well as the Pertronix? Thanks in advance for any help you might provide.
Author:  Old Car Scott [ Fri Feb 25, 2011 9:08 am ]
I love Summit's cheapy $20 high voltage coil. I have them on two vehicles right now and I've never had a problem with them before.
http://www.summitracing.com/parts/SUM-G5217/
