| biggest N20 shot https://slantsix.org/forum/viewtopic.php?t=43792 |
Page 1 of 2 |
| Author: | Junior [ Fri Feb 25, 2011 10:56 am ] |
| Post subject: | biggest N20 shot |
on a stock motor that will hold up. 50-75? |
| Author: | Doc [ Fri Feb 25, 2011 11:06 am ] |
If the engine is in good condition, 50-to 75 horse shot should not be a problem. I've put that much an many stock Slants... "wakes them up" good. DD
| Author: | Junior [ Fri Feb 25, 2011 11:12 am ] |
yeah the motor runs like a top. i have a backup in case anything happens. if a 75 shot wakes it up would a 100-125 shot make it scream? would it hold it? thats a crazy little setup you got there. i was gonna run a base plate system, i have the offy 4bbl and 2 1/2 exhaust on it if that makes a difference. |
| Author: | Doc [ Fri Feb 25, 2011 11:23 am ] |
As you move past 75 HP of N2O, pay special attention to the fuel system and the ignition system. At higher HP shots, a dedicated fuel system with an adjustable regulator and a pressure gauge is needed. I have found that a top quality ignition set-up is also needed or else you get mis-fire with lot's of spray. DD |
| Author: | Junior [ Fri Feb 25, 2011 11:49 am ] |
ok, thank you. ill just run the 75 and see what happens |
| Author: | polkat [ Fri Feb 25, 2011 2:43 pm ] |
Doc, interesting picture and setup! Have you documented that anywhere? Thanks! ________ Jeep honcho history |
| Author: | Doc [ Fri Feb 25, 2011 3:13 pm ] |
Not much to it, most everything is shown in the photo. Note that I have a 3rd 'nos only' nozzle mounted in-board, between the inner manifold mounting bolt hole and the carb base opening. That nozzle sprays a small shot of pure NO2 right into the incoming A/F mix coming through the 1BBL carb. The only trick, making sure you clear the carb. & linkage with the fogger nozzles and pointing the spray paths so you get good mixing with the incoming A/F. I am very pleased with how this systems works, the distribution is great and it took 3 seconds off my stock SL6. (from mid 18's to mid 15's on the spray) DD |
| Author: | 1974duster kev [ Fri Feb 25, 2011 3:16 pm ] |
75 shot should be good i put a 100shot on my old motor and that motor was running 9.6's in the 1/8 without the nos so it got fun with the bottle on. Kev |
| Author: | ryandcovalt [ Fri Feb 25, 2011 9:15 pm ] |
I have cast pistons in my dart, and use an offy 4 barrel, and edelbrock 600 carb. A 50 shot took my car (3300lb street car) down from 14.8 to a 14.0 without any tuning, I basically just cut the timing back. I think you might be surprised what it will do. Especially once you tune your engine for the 75 shot. Problem is we always want more. I will most likely be spraying much more this year, but I will also be using an egt sensor and air/fuel ratio meter to try to make sure it doesn't go lean with the higher hp. I had the opportunity to run with Charlie S. on a test and tune night last year, and i got to see his car go from a 17.?? to mid 13's using 125 shot on a 170 engine. I was very surprised. |
| Author: | emsvitil [ Fri Feb 25, 2011 10:34 pm ] |
Keep adding 25hp until engine blows. Install new engine and go back to shot size that didn't blow engine............ |
| Author: | Charrlie_S [ Sat Feb 26, 2011 4:52 am ] |
Quote: Keep adding 25hp until engine blows.
Nahw, just pull some piston out of the old spare engine in the corner, install with new gaskets, done. About $30 Install new engine and go back to shot size that didn't blow engine............ |
| Author: | Charrlie_S [ Sat Feb 26, 2011 5:00 am ] |
Quote: I had the opportunity to run with Charlie S. on a test and tune night last year, and i got to see his car go from a 17.?? to mid 13's using 125 shot on a 170 engine. I was very surprised.
That was the first time that car had been to the track in 2 years. The engine is a totally stock short block, just a cam and bolt-on's, with the nitrous. Don't run too much timing, and don't go lean.
| Author: | stealth swinger [ Sat Feb 26, 2011 12:21 pm ] |
I run low 8's in the eighth mile with 100 shot, .435 lift cam, and the clifford setup |
| Author: | Junior [ Sat Feb 26, 2011 8:19 pm ] |
i guess i could do that
| Author: | slantzilla [ Sun Feb 27, 2011 9:36 am ] |
I've run as high as a 150 shot on hyperteutectic pistons that everyone said you could not spray. They were fine. 175 shot with a fuel rich tune-up was not fine. |
| Page 1 of 2 | All times are UTC-07:00 |
