Idle Mixture Screws
https://slantsix.org/forum/viewtopic.php?t=43823
Author:  Philip's66 [ Mon Feb 28, 2011 5:08 pm ]
Post subject:  Idle Mixture Screws
I'm tearing down my carter BBD for a rebuild. When i removed the idle mixture screws ,One was longer than the other& Had more taper than the other. The shorter one was broke was able to push the tip back w/ a pencil eraser and it fell out. In all my diagrams it shows them both to be the same. WTF?
Any one else run into this ,Does this matter? I am ordering new ones If they are the same i will reinstall in correct locations. I did document which side had long & short,Can anyone HELP!!
Author:  olafla [ Mon Feb 28, 2011 5:30 pm ]
They are not original - or at least one of them is not, when you get the new ones, you will see that they should be of equal length.
Olaf.
Author:  BUCKET 636 [ Mon Feb 28, 2011 5:54 pm ]
I have 2 Carter BBD high tops,while both have the same length screws in each carby,from one carb to another they are different tapers.These aren't the super six ones.
Author:  SlantSixDan [ Mon Feb 28, 2011 6:55 pm ]
They should both be identical. A good carb kit from Daytona Parts will have new needles in it (and a redesigned inlet needle/seat for better fuel control)
Author:  Philip's66 [ Mon Feb 28, 2011 7:53 pm ]
I should have known to check with the expert's here first. I will remember Daytona from now on. I suspected as much about the screw not being original. brings to mind not to buy reconditioned.
In youth we learn in Old age we understand. I think this site is by far one of the best I have come across for information.
Once again thanks to all of you here at Slant Six .
Author:  SlantSixDan [ Mon Feb 28, 2011 8:47 pm ]
In youth we resent and protest being forced to take naps.
Once we turn thirty, we want back all those naps we refused to take.
Author:  Old6rodder [ Mon Feb 28, 2011 9:39 pm ]
:lol:
.... and past 60 they take us.
ps. Thanks for the link.
Author:  Philip's66 [ Mon Mar 07, 2011 5:35 pm ]
Just an update. Still trying to get screws from Daytona Parts. The Long Screw will not interchange in the base w/ the short side . Kinda figured thats right, makes me wonder what I got from the rebuilder all those years back.
