| Piston height? https://slantsix.org/forum/viewtopic.php?t=43824 |
| Author: | polkat [ Mon Feb 28, 2011 5:15 pm ] |
| Post subject: | Piston height? |
So what is the standard piston negative deck height on the very early 70's 225's? The average seems to be .160" down in the hole. Does that sound about right? ________ Maryjane |
| Author: | Doc [ Mon Feb 28, 2011 5:20 pm ] |
Yes, that is about right... but measure your actual engine to find your exact height. I have see some engines go as deep as -.210 and some right at -.140. Most are in the -160 to -.180 range. Bottomline, actual static comprssion ratios were "all over the map" with a factory SL6. DD |
