| Ranger rear end into a Dart? https://slantsix.org/forum/viewtopic.php?t=43838 |
| Author: | 73dartneedswork [ Tue Mar 01, 2011 8:44 pm ] |
| Post subject: | Ranger rear end into a Dart? |
I’m interested in putting a Ford Ranger 8.8 rear into my Dart. From wheel mounting flange, to wheel mounting flange the width is about perfect. My concern is the pinion offset. The passenger side axle width is a lot shorter on the Ranger. Has anybody done this swap with out changing the axle width? I know about using an 8.8 out of an Explorer, but I was hoping to save the cost of shortening the axle housing. I got a couple of quotes to have Suregrip added to my 8.25. The prices ranged from $550 to $650 and that’s with keeping all the other internals that have 180 thousand miles on them, the same. Thanks for any help. |
| Author: | Fopar [ Tue Mar 01, 2011 9:37 pm ] |
I used a Ford 8" in my 63 Dart, same kind of offset, no real problem. Richard |
| Author: | Old Car Scott [ Wed Mar 02, 2011 3:41 pm ] |
Here's another option: Look for a suregrip out of a mid 90's and earlier Jeep with the 8 1/4 in the junkyard, it'll be much cheaper and you might get better gears while you're at it. Then you can pay someone hourly to install the goods into your rearend, shouldn't take more than two hours if they're really slow, or you could buy the tools and learn to set up differentials yourself. It seems a lot more intimidating than it really is. |
| Author: | volaredon [ Thu Mar 03, 2011 7:41 pm ] |
$600-700; YIKES! Is that with them getting the SG unit and new bearings too? Watch Ebay. 96-older is what you need so the spline count is the same as yours; if you find a 97+ rear in a yard whole, it may be easier to try and install whole; minus possibly having to move spring perches. that is why i will never "have" anything done to my vehicles other than by ME. |
| Author: | pishta [ Thu Apr 21, 2011 9:54 pm ] |
pinion offset is no big deal, as long as they are parallel to the transmission, its good. 8.8 is beefy, I have one in my yard that needs its long side cut to the short side length for a friends 69 451 Cuda. |
| Author: | DonPal [ Fri May 06, 2011 6:32 pm ] |
Quote: Here's another option: Look for a suregrip out of a mid 90's and earlier Jeep with the 8 1/4 in the junkyard, it'll be much cheaper and you might get better gears while you're at it.
Do I understand this correctly.....a 65 Dart 7 1/4 rearend will accept the suregrip/gear assembly from a 96 & earlier Jeep?
Then you can pay someone hourly to install the goods into your rearend |
| Author: | Joshie225 [ Fri May 06, 2011 6:46 pm ] |
An 8 1/4 differential will only fit an 8 1/4 housing. It will not fit any 7 1/4. |
| Author: | Mike_64_Valiant [ Wed May 11, 2011 6:08 pm ] |
I thought the jeep 8.25 was wider than the a-body 7.25. Can some one measure the wheel mount spacing to wheel mount spacing on an a-body 7.25? |
| Author: | Joshie225 [ Wed May 11, 2011 7:03 pm ] |
The Jeep rear axle is wider than the A-body rear axle. Many Jeeps also have Dana rear axles rather than the 8 1/4. We have measured and posted that dimension. |
