Ignition box with rev limiter
https://slantsix.org/forum/viewtopic.php?t=43864
Author:  Slanteast [ Thu Mar 03, 2011 11:49 am ]
Post subject:  Ignition box with rev limiter
Good day to all, I've built a slant with a street /strip theme in a four speed. I'm wondering what to run for ignition? I would like to know what to run for an ignition box?, I would like to have one with a rev limiter if possible since a missed shift is inevitable.
My stock combination had already been upgraded to Mopar electronic (orange box) When the engine was run on the dyno I used the stock distributor with the electronic pick up but they had their own MSD on the dyno. My engine has slightly over 10 to 1 compression, what is the best box for this application?Is the Mopar stuff sufficient? Or an upgrade a must?
I appreciate any and all comments.
Thanks Derek
Author:  slantzilla [ Thu Mar 03, 2011 3:02 pm ]
Easiest thiong to do to get a good box with a limiter is to get an MSD-6AL. The L means limiter. You can run it off your stock Mopar EI distributor.
Author:  SV162 [ Thu Mar 03, 2011 5:10 pm ]
The Crane Hi-6 ignition is another good option. I've been using one for a few years now. It's very good. Pretty much the same thing as the MSD-6AL but the Crane is digital and has dials to set rev limit instead of plug in rpm chips. The Hi-6 also has a few other neat functions, tach test mode is one, used for testing tachometer and shift light accuracy without even starting the engine.
Author:  Exner Geek [ Thu Mar 03, 2011 5:29 pm ]
I have had problems getting MSD accessories like the rev limiter to work with the Chrysler ignition. I finally put in a 6AL and it has worked well since with lots of street driving. Not that much more expensive than buying all the add on do-dads.
Author:  Slanteast [ Fri Mar 04, 2011 4:16 am ]
Thanks for the input from everyone, I'll look into both of these. The dial option sounds appealing.
Thanks again Derek
Author:  emsvitil [ Fri Mar 04, 2011 3:21 pm ]
Summit has a rebadged version of the Crane Hi-6 (I'm assuming this because it looks the same with all the same features).
The only difference I can see is that the Summit version doesn't have a CARB EO number...
Author:  SV162 [ Fri Mar 04, 2011 11:32 pm ]
I just had a look on the Summit website, the Summit box has a much lower spark output compared to the Crane Hi-6. Unless it's a typo. :?
Author:  slantzilla [ Sat Mar 05, 2011 1:02 am ]
It's probably a Chinese knock-off. :shock:
