It is currently Sat Nov 14, 2026 11:04 am
 Post subject: Beefing up the 7-1/4?
PostPosted: Sat Mar 05, 2011 9:47 am
I've been told that one thing which helps is to install a posi (or whatever Mopar called it), but are there any other parts out there...or just go 8-1/4?
________
Meth Rehab Dicussion
PostPosted: Sat Mar 05, 2011 7:38 pm
Site Admin
Depends on what kind of power your going to make. SureGrip is the name for it.
I went with an 8" Ford rear out of a 72 or so Ford maverick. Drops right in. A driveline shop welded a ford end on the back of my driveshaft, so it runs over the counter U-Joints. The 8" will handle just about anything a highly modified slant will throw at it, and there are inexpensive lockers available. Shock plates from a large tube rear will be needed, along with appropriate U-bolts.
The 8-1/4" is a good choice for a hopped up slant six. Suregrip is a darn good idea. Being one legged is a pain at the strip. letting the air out of a tire, then pumping it back up to go home isn't much fun.
2¢
CJ
PostPosted: Sun Mar 06, 2011 8:58 am
Adding a sure grip to a 7 1/4 helps them a lot but finding a good SG unit for a 7 1/4 is hard and can be expensive.
There is not much else you can do to an open unit... the spider gears are just too small to carry any high loads.
Users browsing this forum: Amazon [Bot] and 1 guest
