It is currently Sat Nov 14, 2026 5:54 am
 Post subject: 66 valiant
PostPosted: Wed Mar 02, 2011 7:27 pm
i have a 66 valiant, i put in an 8 1/4 rear. the driveshaft is about 2 1/2 inches too long but there are three holes in the mounting pad so i just moved it back and bolted it up. the center section and the shocks now hit the gas tank. is there any stock driveshaft that will bolt in and let me move the rear forward again?
PostPosted: Wed Mar 02, 2011 8:13 pm
Actually, the original driveshaft will be 1.6" too long. I think a driveshaft from a Duster with an 8 1/4 will be close. What's your driveshaft length from the center of one U-joint to the other?
 Post subject: Yep...
PostPosted: Wed Mar 02, 2011 11:34 pm
+1 on that...
PostPosted: Thu Mar 03, 2011 6:06 am
Those 3 holes on the housing perches are not for adjustment. Only the middle one should be used. You need to find or make a shorter driveshaft and put your axle back in the centered position where it should be.
PostPosted: Thu Mar 03, 2011 9:08 pm
i dont remember the length off the top of my head ill remeasure tomorrow.
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Thu Mar 03, 2011 9:10 pm
yea i know that. the township i live in has nothing better to do than drive around spending taxpayers money so they can try to find something to write a ticket for. i just did that so it looks like its operational
