A833 OD Source Vehicles
https://slantsix.org/forum/viewtopic.php?t=43871
Author:  husker1 [ Thu Mar 03, 2011 7:30 pm ]
Post subject:  A833 OD Source Vehicles
I have a '71 D100 /6 3speed. interested in putting an overdrive trans in it. I have looked at the T5 swap and am interested in that but thought the A833 OD swap might be a little easier. What source vehicles should i look for at my local junk yard? What issues will i have with this swap?
Thanks
Author:  DusterIdiot [ Fri Mar 04, 2011 5:20 am ]
Post subject:  These vehicles...
1975-1987 Dodge Trucks/Vans (Also similar year Plymouth Trucks/Vans)
You will need the bellhousing, tranny, shift rods and shifter. You should have everything else you need already on your 3 speed vehicle.
You may need the floor hump if your rig is a 3on the tree.
Author:  hantayo13 [ Fri Mar 04, 2011 7:59 am ]
where are you ???? I have a setup here in northeast Pa
Author:  Old Car Scott [ Fri Mar 04, 2011 4:31 pm ]
ESP47 on here is doing this swap right now or soon.
