| Holley 1920 Carb ID https://slantsix.org/forum/viewtopic.php?t=43896 |
| Author: | wvenable [ Sat Mar 05, 2011 3:09 pm ] |
| Post subject: | Holley 1920 Carb ID |
SSD and others, help! Trying to gather up some carbs so I can hopefully find a rebuildable pair for a Offy dual 1bbl set up (5041). Maybe someone can tell me if I have a couple compatable match. Carb 1 1 5/16 12R-7611B (side of Bowl) 6260 2 0356 stamped on vertical surface along same plane as Holley marking Carb 2 1 5/16 12R-7611b (side of bowl) 6260 2 0987 #'s found in same local carbs 1&2 look almost identical Maybe thats why the #'s are similar. duh. Carb 3 1 5/16 12A-5592B 6594 2582 3698347 same place as above 263 26 #'s facing the sky Carb 4 1 5/16 12A-4285B 0422 05156 4392 #'s facing sky Carbs 3 & 4 are earlier (I think). Carbs 1 & 2 were recently purchased from the Bruners. Hopefully you expert types can tell me the application and whether or not I have two that will work as a unit. Thanks, Wayne. |
| Author: | SlantSixDan [ Sat Mar 05, 2011 8:34 pm ] |
| Post subject: | Re: Holley 1920 Carb ID |
6594: 1973 225/auto, Federal emissions (with EGR) 6260: Go fish, not in my list at the moment 4392: Go fish, not in my list at the moment I don't have my master Holley book with me; I could swear I've seen 6260 before. Think it might be a service replacement carb for '67-'72 applications. If nothing else, you've got two same-number carbs, a decent start (though two new matched carbs would be better). |
| Author: | wvenable [ Sat Mar 05, 2011 8:58 pm ] |
Dan, thanks for the help so far. I have a couple more 1920's on the way and have my fingers crossed. |
