Lifter Clatter
https://slantsix.org/forum/viewtopic.php?t=43912
Page 1 of 2
Author:  krosan [ Sun Mar 06, 2011 5:58 pm ]
Post subject:  Lifter Clatter
Hello Gurus'
I have a question on lifter clatter on my #6 exhaust valve. I've had this noise since I bought the car this winter. I've read all the good information in this forum about valve adjustments so I attemped to do the hot adjustment. Old #6 clattered until I was down to .006. I was getting little to no oil the lifters. Soooo... I decided to pull the rocker arm and then I decided to pull the head off get a valve job done with the hardened valves and seats. Today was put together day. I did a cold valve adjustment and then a hot one. Old #6 still clatters away as before. I used the same pushrods am using 10-30 Chevron 5000 oil.
Does anyone have any ideas what may be wrong here?
Author:  ceej [ Sun Mar 06, 2011 6:45 pm ]
Ideas:
1. Did somebody put a hydraulic lifter in there?
2. Did you examine the lifters for wear prior to reinstalling the pushrods?
3. Are the pushrods straight? If you have a bent one, it can flex and clatter.
CJ
Author:  Fopar [ Sun Mar 06, 2011 7:02 pm ]
Maybe the long clattering caused the rocker-arm to develope a recessed tip on the valve end.
Richard
Author:  krosan [ Sun Mar 06, 2011 8:09 pm ]
I didn't examine the lifers but I checked the rods for straightness. Will a hydraulic lifter even fit? It looks like the engine was rebuilt and then the car was parked under a big pine tree long enough for the gas to turn into varnish. The cylinder walls still had the cris-cross pattern on the walls. Even the machine shop said that the head looked as though it had been worked on.
Can I reach in the spark plug hole with a magnet and pull the lifter out? If it is the lifter, can you replace only one or do I need to replace all of them?
Author:  ceej [ Sun Mar 06, 2011 8:28 pm ]
With the valve cover off, you should be able to pull the lifter straight up once the rockers and spark plug tubes are out of the way. If there is damage to the lifter face, you may need to replace the cam. Inspect it carefully.
If somebody put a hydraulic lifter in there, replace it with a mechanical. Just in case, I'd replace all of them with new lifters. Check the rockers for damage. If the tip of the one on number six has a bad tip, like Fopar suggested, you should replace that rocker.
CJ
Author:  Joshie225 [ Sun Mar 06, 2011 8:29 pm ]
If you find a lifter down the spark plug hole you've got bigger problems than a noisy valve. :shock:
If you had a valve job done the tip of the valve should be in good shape, but what does the tip of that rocker arm look like?
Yes, a hydraulic lifter is the same diameter as the solid and will go in the hole. If the cylinder head has spark plug tubes you should be able to pull the lifter once the valve cover and valve gear are removed. If the other pushrods are spinning as the engine runs they're probably fine.
Author:  krosan [ Sun Mar 06, 2011 10:36 pm ]
I was referring to the spark plug tube. Even this retired County worker knows not to go poken into the spark plug holes, looking for lifters. LOL ... Thanks All for the input.
Author:  wjajr [ Mon Mar 07, 2011 6:42 am ]
Are the oil distribution holes along the rocker shaft pointing in the correct direction: to valve springs? Also did you clean out oil passages in all rockers, being carful to keep them in same order on shaft?
Do the push rods rotate when engine is running? If some don’t, there is a lifter or cam surface problem at those rod locations.
Author:  krosan [ Mon Mar 07, 2011 11:56 am ]
I pulled the last to lifters to compare and all seems good there. I also checked the rockers sockets and oil passages. The oil passages are plugged. (I didn't even know they were there) I tried to clean one with a piece of spring wire which worked good until I got to where the hole curves to the inner hole. I had already soaked all the lifters in carbureator cleaner when I was having the head done. Do anyone have a method that works to clean these things?
Author:  Valleyant [ Mon Mar 07, 2011 12:47 pm ]
krosan,
Click on articles on the home page and go to Slant Sixness Hot Rod Magazine article from Nov, 2000 and click on page 3...says if you find a rocker arm that is plugged it is best to replace it. Glad you found the problem.
Author:  krosan [ Mon Mar 07, 2011 3:08 pm ]
Thanks for everyones input. It looks like I'll be buying new lifters.. :oops:
Author:  krosan [ Mon Mar 07, 2011 3:38 pm ]
I guess I should have said rocker arms.... :roll:
Author:  Joshie225 [ Mon Mar 07, 2011 4:10 pm ]
You might be able to salvage some by dunking them for a few days in carburetor cleaner. I'm talking the real stuff that comes in pails and eats paint and carbon like buttered popcorn.
Author:  gato [ Mon Mar 07, 2011 4:22 pm ]
i got some of that stuff! it works great!
just make sure u blast it with compressed air to make sure ur passages r good and clean. but if u r left with any doubt when ur done. . . replace.
Author:  Fopar [ Mon Mar 07, 2011 4:25 pm ]
Josh you might note he lives in Calif and most good items have been known by the state to cause cancer. :lol:
They might have banned the sale of such good stuff. :roll:
Richard
Page 1 of 2 All times are UTC-07:00
