It is currently Sun Nov 15, 2026 8:03 am
PostPosted: Wed Mar 02, 2011 5:46 pm
Anyone no where i can but the little vaccum tree on the intake manifold ?
Thank You!
PostPosted: Wed Mar 02, 2011 6:13 pm
Hi zk6216.
That little vacuum tree is made from an inferior alloy, and is also a constant source for vacuum leaks.
Unless you are restoring to absolute original state, you should replace it with a single, high quality nipple (for power brake vacuum only) , fastened with loctite or similar locking fluid in the threads.
If you have other vacuum lines on the tree, it is better to tee them off carburetor vacuum lines, taking vacuum from the single manifold branch, will give a somewhat erratic vacuum signal.
Olaf.
Aspenized
 Post subject: Um...
PostPosted: Wed Mar 02, 2011 11:32 pm
Junkyard would be my first selection...the 73-76 slants got one with a single tap for the vacc. amplifier/EGR....the later 77+ seem to have multiple taps for brakes/amplifier/EGR/Thermactor...There are other versions to be found on late small block manifolds as well.
I've never had the problem that Olaf seems to indicate, stock or transplanting a super six with the multi-tap version. Cinch into place, use sealant if dubious of the seal (light RTV on threads=OK)...
PostPosted: Thu Mar 03, 2011 5:26 pm
Where can i find a single nipple, and how do i branch them?
PostPosted: Thu Mar 03, 2011 6:29 pm
if it doen't "have to be" original
try looking in a fish store
lots of bits and pieces for air lines there
including brass valves and T's etc.
dan
"I may be slow, but at least I'm not very fast!"
'69 A108 - 225, 727, 3.55, MSD6AL, a.k.a.-the brick
PostPosted: Sun Mar 06, 2011 6:22 pm
home depot, advance autoparts, auto zone (both parts stores will have the brass brabbed fittings in the back), car quest,
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Mon Mar 07, 2011 9:02 am
I have a coffee can full of used factory ones... all different shape & sizes.
Send me a PM with the type you need and I will see if I have one.
Users browsing this forum: Amazon [Bot] and 7 guests
