| can a 65 automatic use the tail of a newer 904? https://slantsix.org/forum/viewtopic.php?t=43927 |
Page 1 of 2 |
| Author: | ppsi [ Mon Mar 07, 2011 5:05 pm ] |
| Post subject: | can a 65 automatic use the tail of a newer 904? |
I have the old trunion style transmission in my Dart. I also have a slant 904 in a storage building that I've not looked at in a while. I am wondering if I could remove the tail from the newer 904 and put it on my current transmission and get a new drive shaft made so I can use conventional style universal joints. I might as well totally expose my ignorance by asking is it possible the newer style 904 has a different internal gearing for the final drive than my 65. I figure both are 1:1 but my Dart revs high and it has an 8 1/4 with low 300 ratio (323?) gearing. It isn't slipping but just revs at 3000+ when going 55 mph. |
| Author: | bigslant6fan [ Mon Mar 07, 2011 5:08 pm ] |
| Post subject: | . |
No, It's completly different |
| Author: | Joshie225 [ Mon Mar 07, 2011 7:51 pm ] |
Not only doesn't it work, all A904 transmissions have the same 1:1 high gear ratio. |
| Author: | Charrlie_S [ Tue Mar 08, 2011 5:24 am ] |
PPSI, You can modify your drive shaft like this. http://www.earlycuda.org/tech/ujoint.htm |
| Author: | Rug_Trucker [ Tue Mar 08, 2011 3:46 pm ] |
3:23's= 3000@ 70mph or somewhere near that. Depending on tire height. |
| Author: | ppsi [ Tue Mar 08, 2011 6:38 pm ] |
Quote: 3:23's= 3000@ 70mph or somewhere near that. Depending on tire height.
Maybe I need to bring a tach on my next trip. I've converted the car to 15" wheels which should slow the engine down even more????Thanks-Howard |
| Author: | ppsi [ Sat Mar 12, 2011 4:28 pm ] |
I could put this transmission in this Dart but I am about to put a console in it from a cable shift car. Is there a conversion kit to go from cable to linkage? Thanks Howard |
| Author: | Joshie225 [ Sat Mar 12, 2011 4:34 pm ] |
Quote: I could put this transmission in this Dart but I am about to put a console in it from a cable shift car. Is there a conversion kit to go from cable to linkage?
Use the '66 stuff to make it rod shifted.
Thanks Howard |
| Author: | Rug_Trucker [ Sat Mar 12, 2011 7:16 pm ] |
65 tranny is a 1 year only that was cable shifted. No trunion, and can be push started! |
| Author: | Charrlie_S [ Sun Mar 13, 2011 4:52 am ] |
Quote: 65 tranny is a 1 year only that was cable shifted. No trunion, and can be push started!
65 tranny DOES have a trunion. It is one year only, because of a different valve body. A 64 older push button trans can be converted to a 65 trans, by changing the valve body (using a 65 VB), to work with the non push button cable shifter. 66 trans uses "mechanical" shift linkage, has no trunion, and cannot be push started. It has a different speedo connection. 67 trans is the same as 66, 68 trans had a major change, due to using a larger input shaft, and a larger pilot "nub" on the converter. Because of this change the 68 and later trans/converter cannot be used with a 67 and older engine. Edit: corrected info about speedo connection. |
| Author: | Charrlie_S [ Sun Mar 13, 2011 5:02 am ] |
There is a conversion kit, but it is for the pushbutton cable shifter to later mechanical shifted trans. Very expensive. I see they now have a kit for the non push button shifters, that is not too pricey.Thanks Howard http://www.imperialservices.net/Aparts.html Scroll down. |
| Author: | slantzilla [ Sun Mar 13, 2011 7:31 am ] |
My trans guy converts trunnion tails to slip yoke all the time. You have to change a lot of stuff though, it's not a simple thing. |
| Author: | Charrlie_S [ Sun Mar 13, 2011 9:42 am ] |
Quote: My trans guy converts trunnion tails to slip yoke all the time. You have to change a lot of stuff though, it's not a simple thing.
In my opinion, that is not cost effictive. Yes it can be done, but that doesn't mean it should be done. Easier/cheaper to either change the complete trans to a newer one, or do the driveshaft conversion.
| Author: | slantzilla [ Sun Mar 13, 2011 12:41 pm ] |
Some guys just want to retain the PB/cable shift. I don't think he charges a whole lot more than just s standard rebuild price either. Hell Charlie, not everyone is like us Slant racers. Some people actually have too much money. |
| Author: | SlantSixDan [ Sun Mar 13, 2011 2:21 pm ] |
Quote: Some guys just want to retain the PB/cable shift.
Solution: convert the driveshaft.
| Page 1 of 2 | All times are UTC-07:00 |
