It is currently Sun Oct 11, 2026 2:45 pm
 Post subject: Holley 6145 connections
PostPosted: Wed Mar 23, 2011 3:09 pm
Could someone direct me to a picture of a Holley 6145 that has all the vacuum lines correctly routed to it? I think I finally got mine all set up right, but the FSM I have skips over some of the ports, and the diagram under the hood isn't in the best condition.
Thanks!
1981 Lebaron with 225; all original, save for a door.
PostPosted: Wed Mar 23, 2011 8:23 pm
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
PostPosted: Thu Mar 24, 2011 11:39 am
thank you. I did see that, but the 1945 is slightly different than the 6145. And looking at my engine today, I think I have it set as correctly as can be without the some of the smog stuff that the prior owner removed.
PostPosted: Mon Apr 18, 2011 12:26 pm
Do you still need these pics? I took a bunch the other day before I removed mine.
BTW - Does anyone know if the 1945 and 6145 throttle shaft bushings are interchangeable?
PostPosted: Mon Apr 18, 2011 1:26 pm
I don't think I need them anymore. I suppose I'm still not positive if I have everything correct, but it's running fine. If you could post them, it would be appreciated, but no big hurry.
Users browsing this forum: Zane and 9 guests
